Import policy affecting an Adj-RIB-In has been changed while the "soft reset with stored routing information" behavior is enabled. The routes in the given Adj-RIB-In are recalculated from a list of all the candidate routes that have been received from the associated peer. Import policy is re-applied to these candidates, and the Adj-RIB-In is adjusted accordingly.
No action required - Informational message only. May be of interest to operators and developers to trace and debug events
Info
[VR %p1%]Recalculating Adj-RIB-In: <Peer index=%p2%, afi-safi=%p3%-%p4%>, import policy changed
| Name | Type |
| p1 | uInt32 |
| p2 | xInt32 |
| p3 | uInt16 |
| p4 | uInt8 |
